p0355b ignition control 5 circuit???
i checked my service engine light today and came up with p0355b ignition control 5 circuit...thinking it might just be my #5 coil pack acting up, i replaced it with an extra i had and reset the code. After a couple of minutes, the same code popped back up. i checked to make sure the 2 plugs were secured and am still getting this code...anyone have any idea what might be goin wrong?
i just checked the main terminal that connects all the injectors to the coil packs and when i moved it the idle would change on me. as i unplugged it, i noticed green corrosion on one of the tooths as well as on its female connector...could this be my problem? if so, can i get this cleaned off or would it require replacement?
