1995 z28 lt1...whats making my car jump when taking off??
Old 09-04-2008, 11:02 PM
cody8892000's Avatar
Default 1995 z28 lt1...whats making my car jump when taking off??
alright when im driving my car down the road going like 55 and i let off the gas and then get back on it...it goes perfectly fine....if i floor it and it down shifts from 4th to 3rd or 3rd to 2nd....it goes perfectly fine.......and if im sitting still and SLOWLY take off....it goes perfect.....the problem is:
when im sitting still and i push the gas half way or more the whole car jerks forward pretty damn abruptly like its the U joints...i have to kinda get on it to make it do that though...and it makes a rough sounding noise like it hits and then takes off as if the u joints are going out and you can hear most of the noise coming from the drive shaft or transmission......atleast it seems like thats where its comming from..........it also does it shifting from 1st to second when im really gettin on it or when i make it downshift to 1st it does it really really bad
also my transmission only has about 1000 miles on it...i just had to have it rebuilt $1500 gone...it sucked
Old 09-05-2008, 08:33 AM
the_merv's Avatar
You could have broken the Trans Mount..
Old 09-05-2008, 10:22 AM
Formula96's Avatar
Trans mount gets my guess...
Old 09-05-2008, 11:17 AM
Fixxer99TA's Avatar
This is what it sounds to be....
Old 09-05-2008, 01:25 PM
3pnt4maro's Avatar
trans mount...there is a lil piece that is attached to the tranny that is going up and down on the tranny mount...it is hitting all the threads as it goes up and creates that god awful sound
Old 09-05-2008, 06:28 PM
k0261886's Avatar
wheel hop maybe? That makes my car jump pretty damn hard.
Old 09-05-2008, 06:31 PM
67goatman455's Avatar
mine was, and now is again doing the same thing, my problem, the two bolts that attach the torque arm to the rear end have slotted the torque arm holes (i have no idea either), check to see if it looks like the washers around the bolts have been moving on the torque arm....
Quick Reply: 1995 z28 lt1...whats making my car jump when taking off??
