TA Circuit Breakers?
Does the 4th generation TA have circuit breakers that protect electronics if the positive terminal of the battery gets disconnected first? I think the positive line was a bit loose, and when I tried to start, all power just shut off. I moved the battery around, and heard the power turn on and was able to start then. Was the shutdown from the circuit breaker?
Also, is there any chance of equipment damage if the positive terminal touches the AC canister right behind with a spark? I made accidental contact when moving a wrench and socket through the space in between.
