Which wiring harness do I need?
Old 09-09-2008, 09:29 PM
1stGenL92's Avatar
Default Which wiring harness do I need?
I need a little help in my change of plans on my current project. I have a truck 6.0L LS motor I'm putting together for my '67 Camaro. I bought the GMPP 4 barrel intake. I've changed my mind a little there. I'm going to run the manifold with a Wilsons Manifolds elbow and my stock throttle body. to getting it running and change to a 90mm this winter. My question is, do I need the trucks engine wiring harness and ECU or do I need a Camaro LS1 engine wiring harness and ECU?
Old 09-09-2008, 09:38 PM
2000lsxs10's Avatar
Here you go this is what i bought and it works great. they have other models if your not running a 4l60e trans.....http://cgi.ebay.com/ebaymotors/ws/eB...250507309&rd=1.... this is the cheapest place i found... but you do need a stock ecm, and the vats do need to be taken off the stock ecm.... but it is headache free..... good luck
Old 09-09-2008, 09:44 PM
Rodder's Avatar
You can make either one work. Do you already have sensors, injectors, coil packs, etc? If so, get the PCM and harness that match. In particular, you need a PCM that matches your crank reluctor (24 tooth versus 58 tooth). What model/year is your 6.0?
Old 09-09-2008, 09:58 PM
1stGenL92's Avatar
My 6.0L is from an '02 and I have everything(coils, sensors) except for the wiring harness. I also have the MSD 6LS for it. I'm running a TH350, and I'm going to add a Gear Vendors overdrive if the motor doesn't cost me a ton more to get running this way.
Old 09-09-2008, 11:53 PM
2000lsxs10's Avatar
that link i sent is the way to go.... the harness is brand new... and not a hacked up factory harness... it has eveything you need to just plug it in hook up your hot and ground and away you go
Old 09-10-2008, 12:19 AM
NMJ87T2's Avatar
You could also contact www.jimsperformance.com He does great work. He can build you a custom harness. I think his price starts at $395. If you send him a harness and pcm he can get you rolling with a few wires to hook up, a DLC,fuse block,fuel pump relay, and work on the pcm for about $520.
Quick Reply: Which wiring harness do I need?
