LCA relocation brackets for Moser 9 inch
Old 09-10-2008, 07:05 PM
ZMONSTER!'s Avatar
Default LCA relocation brackets for Moser 9 inch
Hey all do any sponsors make a bolt in LCA relo bracket for a moser 9 inch rear end? Ive seen UMI's weld in, and they are my first choice but I didnt see a bolt in that would fit. If someone could square me away Id appreciate it.
Old 09-11-2008, 11:08 AM
UMI Performance's Avatar
As far as I know no one makes a bolt in relocation bracket for the Moser rear end.
The main reason for this is Moser tolerances are loose, we notice there control arms mounts are wider than other times and also there shock mounts tend to be in or out a little more on each rear end. This makes it very hard to build items around and to make items fit properly.
If you are interested in our weld in brackets we are running a 10% off sale until the 15th of this month- www.umiperformance.com/2011
Thank you!
Ryan
Quick Reply: LCA relocation brackets for Moser 9 inch
