oil return size?
Old 09-10-2008, 08:59 PM
SheldonZ28's Avatar
Default oil return size?
hey everyone.
what size should i be doing my oil return into my pan? 3/8" NPT?
Im not turboing yet but ill have the pan off and figured i could put an elbow in and then just plug it so when i put a turbo kit in the engine is ready.
Thanks!
Old 09-10-2008, 09:18 PM
ModularTurbo's Avatar
Oil feed and drain line kit includes everything you need= 100 shipped
Old 09-10-2008, 09:30 PM
SheldonZ28's Avatar
Not looking to buy a kit, i get discount parts from work.
Was just going to do NPT Brass fittings.
Was just asking if a 3/8" NPT is the right size, was going to stick an elbow out of the pan then plug it so when i start my turbo kit i dont need to pull the pan i can just undo a plug and thread the line in.
Thanks!
Old 09-10-2008, 09:38 PM
LS1TECH Sponsor
DrTurbo's Avatar
-10 AN drain and -4 AN feed. You can pick that up easy....
Old 09-10-2008, 10:38 PM
DeltaT's Avatar
I agree a -10 if you have room, but a -8 with nice smooth curves will work too. And make sure the drain on the pan drains above the static oil level or you could have probs.
Jim
Quick Reply: oil return size?
