crank hub and ignition problem
Old 09-11-2008, 09:53 PM
spina74's Avatar
Default crank hub and ignition problem
I had my motor rebuilt by a shop and after I assembled the motor I saw that the crank pulley did not line up with the acc pulleys. I tried to put in on farther but it wont go any farther, does anyone have any ideas or should i put some washers behind the acc bracket and also for the ignition problem yesterday I was able to fire my car up but today it wouldn't crank. Everything works when I turn my key to the on position. My neutral saftey switch on the clutch was by-passed when I got the car. Please can someone help.
Old 09-13-2008, 12:14 AM
spina74's Avatar
t t t
Quick Reply: crank hub and ignition problem
