What elbow is this?
What elbow is this?
Just wondering who makes this elbow, and if it was good for FI. Will be running 408/S91 @ ~17psi. Thanks for any info.
By chriz28 at 2008-09-12
Chris
Chris
That's kinda the issue I had with it. It looks like it necks down pretty tight under the cowl. I've got a tall pin-on hood, so clearance isn't an issue and as long as I don't lose my wipers I don't care to cut. Here's a closer pic of it.
Chris
Chris
Closed ex-Sponsor Account
Hit them up they probably can build you a taller one. I have seen that elbow it does LOOK necked down but is not. The area is larger then the throttle body opening in sq. inches. If you get one make sure you get the boosted one. Thicker material and its double welded.
