need help please
need help please
local junk yard has a rear end for my 94 t.a because i ripped mine out and the only problem is that it has drum brakes. I thought 93 to 97 f-bodies only had disk brakes. Can someone verify.
Yes they will work, but you may not like them. What is your car, auto or manual? If it is a auto it either came with 2.73, or 3.23 gears. If it is a manual it came with 3.42. And, the only thing that I would do with that rear end is take the gears out of it, if that is what failed in your rear end. Everything else on that rear would be completly retarted to put on your car.
