pully installation
Old 09-14-2008, 08:00 AM
SCREAMIN01SS's Avatar
Default pully installation
when you install an ATI super damper, with a A/C pulley and blower pulley- is it better to install the damper and A/C pulley on the crank first and then istall the blower pully (like the directions say) or can you put all three together and put them on the crank at once. Is there going to be a clearence issue?
Old 09-14-2008, 09:41 AM
ZDOG's Avatar
idont see why you couldnt do all at once.
but doing all three you run the risk of hurting the blower pulley if you have to tap it on or get physical with it at all. for the three allen bolts it takes to install id atleast wait until you have the ati balancer fully seated.
Quick Reply: pully installation
