What to spray to rpm wise?
Old 09-16-2008, 05:34 PM
Chhh Chhh's Avatar
Default What to spray to rpm wise?
say my rev limiter is set at 6900 and im using a trick window switch, wat should i disable it at? i would love to be as close as possible with out messin it up..
Old 09-16-2008, 07:30 PM
waterbug1999's Avatar
I have my A4 shifting at 6600. The window switch turn off is set at 6500. Seems to work good and not pinging off the rev limiter that is set at 6800.
Old 09-17-2008, 09:34 AM
bad6as's Avatar
your limiter is at 6900, what rpm do you try to shift at? try a few hundred below what you aim to shift at.
my shift light comes on at 6500. im gonna set the window switch to 6200-6400
Old 09-17-2008, 12:59 PM
8 second mod
Noyzee's Avatar
my vett is at 6600, my shift light comes on at 6400 i shut my spray off at 6300
Old 09-18-2008, 11:32 PM
Chhh Chhh's Avatar
same.
