window and progressive switch
Old 09-16-2008, 11:19 PM
silverz28camaro's Avatar
Default window and progressive switch
I have a standard 50-150 nx wet kit now. I have a 200 auto camaro with all the bolt-on, stall 3600 3.73 and built 4l60e.
I know the 4l60e is the weak point so that is why i am looking into a progressive shot that starts at 75 and progresses to 125 or so.
Also i know that the 3-4 clutch pack is the weak point in the tranny, so adding a window switch that would shut the nitrous off right before the shift may help prolong the tranny life.
How do i do this? I don't know a whole lot about nitrous switches and computer mods for it.
What modules or switches do i need?and will the work with the kit i have now or should i buy an entire different kit?
Old 09-17-2008, 03:10 AM
N4cer's Avatar
A window switch won't matter on that since as it drops in RPMs between shifts it'll spray again because it'll be back "in the window".
Old 09-17-2008, 10:40 AM
torquejunky's Avatar
It's not going to be automatic, but you could wire in a push button kill switch, kinda like how guys with trans-brakes wire an extra relay that triggers off the trans-brake button.
I did this since my window switch did not have an option for locking out first gear.
