wont start no spark
wont start no spark
car was driving fine. stopped at a light took off made a turn and it started to spudder for about 30 seconds then died...
first though was gas...either out or fuel pump but both are fine....
we checked the coil according to shoebox and all was fine...
i replaced the coil with another same problem
replaced the pcm same problem
checked and changed out the opti harness
still have the same problem, any other ideas?
once i found out it wasnt and it had no spark i was confused...
i knew it wasnt the common opti rotor problem...so i checked shbox site...all was good..i swapped coils and ohmed the coil wire no problems there...i then knew it was the icm, swapped it with another and it fired
