To Heavy
To Heavy
hi there i was just wondering what could be done to lighten my 1995 Z28. i already have a fiber glass hood and welds. i kind still want it to "look" stock... thanks matt
Check out Beaflag's thread on what he all removed. He's dropped around 370lbs. https://ls1tech.com/forums/lt1-lt4-modifications/859437-my-new-1993-z28-project.html
OWN3D BY MY PROF!
And keep in mind, doing all that also is quite a hit on the safety front. To add to that, the door support (bar inside the door skin) is also a common removal.
Check out Beaflag's thread on what he all removed. He's dropped around 370lbs. https://ls1tech.com/forums/showthread.php?t=859437
The drag racing section has a weight removal sticky in there that is really good. I got a lot of my ideas from reading that and some older threads by a few members like dlove, Jantzer98ss, RAGENZ28 (mini tubbing info), Magnus, The Juggernaut, and SUX2BU. The ideas are out there. You just have to figure out a way to implement them.
sticky:
https://ls1tech.com/forums/drag-racing-tech/846228-weight-reduction-list-fully-updated.html
