2 Bar map question
2 Bar map question
i think my scaler is off on my 2 bar map, its the cobalt map and it reads only 80 kpa on the timing histogram at wide open throttle, it should be 100 kpa, anyway to adjust that. it could be a 2.5 bar, not totally sure. what do you guys think? thanks
tuned with hp tuner, also it is a 3 bar enhanced sd ol setup, should the timing map go to 210kpa also like the fuel map?
ccar is a A4 ss 370 88mm. running 8-12 psi
