Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
needing help!!!
Old 09-23-2008, 05:22 PM
bigjohnson's Avatar
Question needing help!!!
I'm trying to fix a buddies camaro. It has a weird runability issue that no one can figure out so far. It runs ok 3500 rpm and then it acts like it loses a few cylinders, runs like total **** and wont idle for a bit, and then goes back to running ok again.It's an '02 z/28 6 speed car. Ported throttle body that came off a goat, air box has been modified to move more air, bigger cam, ported heads, headers, no cats, computer tuned by speed inc. The car ran fine for quite some time after these mods, went 12.60s @ 114 mph on street tires. We've replaced the O2 censors, plugs, wires, map censor, maf censor, intake gaskets, fuel pump, fuel filter( was the first thing we checked), and tried an different computer and it did the same ****. It's had a map censor code, the code went away for a short time after replacing it . It was running correctly for about 10 minutes and then it went back to it's old ****. So there you have it, a recipe for making your hair fall out prematurely and money disappearing quickly! The weird thing is...the problem is completely consistant, the rpm at which things go south and the way it returns to "normal" never changes.
Any ideas on how to fix it?
