ls1 edit question non technicial
my car got tuned with ls1 edit. is there a way i can put ls1 edit on my computer and get the cables and use the same liscense or change anything (mainly gears) i like the tune i just want to be able to change something if i ever need to. or is the computer (in car) locked to the computer that did the tuning to the car? thanks
- Scottie
- Scottie
you can put ls1 edit on any computer you like. When you tune your vin number is stored in the cable harness itself and verifys the licence in the box. For you to tune you would need a new cable/program unless you have access to the harness that tuned it originally. Before you order cables and all you need to check up with whoever tuned your car and see if they locked the tune on you meaning you wont be able to change that tune.. If intrested i have ls1 edit and auto tap--(scanner) that im looking to sell-- i currently have hptuners...
