97 PCM w/427 swap
It will work but, you will be limiting your options as far as managing forced induction or N20 with the factory pcm. For this you will need to do a harware upgrade to a 99+up controller in order to run custom software.
Realtime tuning for a setup like this would be optimal for razor sharp results. The Moates Road Runner is availible for the 97.
PS, I have had this car since new with 3 different engines. It's not the fastest I've had, but overall it's the best I've had. Smooth idle with stock Ti Mufflers. A real Sleeper.
Good luck with your project.
Tom.
