Diff Cover Leaking
Diff Cover Leaking
Just had my axles and axle bearings replaced at a performance shop.
I noticed tonight that there was some gear fluid under the TA girdle and traced it up to the pre-load bolts (green arrows in the picture).
They are supposed to be 5 ft-lb torque. Is it possible they overtightened and damaged the bearing caps?
If they did, is the whole cover trashed?
Thanks.
Thanks.
