are TR6 plugs really recommended?
what are you guys running for plugs with what kind of shot? I have TR6s gapped at .035 with my stock motor and shots ranging from 75-150 depending on the day, but i'm wonder if i'm running too cold a plug, and if I should run a larger gap.
They are the right plug if you want to spray. Other wise for just running around NA with your mods I would use a TR55, but for spray you would have to swap to Tr6's when you wanted to use it.
No, it seems to be working good right now, except sometimes I notice in 3rd gear that it almost sounds like the nitrous is kinda oscillating on and off. It's very hard to explain. I'm going to post up a video if I can
The colder the better when you have a power adder that way you will be on the safe side. I use TR6's and they work fine and no on the larger gap .035 is fine maybe even .032-.030
