upper shock bolt
Old 10-01-2008, 05:45 PM
BradsLS1's Avatar
Default upper shock bolt
This may seem dumb but how do you get at the rear upper shock bracket. I tried looking underneath but it is in a tight place. Do I have to go from up top somewhere? I have a squeak up around there that has been driving me crazy.
Old 10-01-2008, 06:02 PM
SmokedOutZ28's Avatar
Yes, its up to in the inside passenger compartment. You need to remove the panels and pull back the carpet and that will expose the upper bolt.
Old 10-01-2008, 06:25 PM
99zee's Avatar
I had a noise coming from there also. I pulled back the carpet and the bolt had worked its way off the stud!! Hopefully its something easy like that.
Old 10-01-2008, 08:29 PM
BradsLS1's Avatar
Thanks guys. I found it. It wasn't the nut just some squeaky rubber. Nothing a little WD couldn't fix.
