cam choice new 2010 camaro stroked LS3
cam choice new 2010 camaro stroked LS3 / build pics
looking for some cam opinions for my new build, im putting together a 415ci LS3 with cnc ported LS3/L92 heads, this engine will be going in my new 2010 camaro, the short block/rotating assy is done and the heads are ready to go.
im was thinking about getting another Comp Cams XR281HR to start with, i had this cam in my 6.0L L92 s-10 and it ran great in that engine and should be even tamer in the larger ci LS3 stroker,, i dont want to go with a huge cam right away until i find out just what will be availible for tuning the new camaro pcm.
engine is done for the most part, just waiting for gm to get the camaro in the parts catalog so i can get the correct oil pan and pick-up tube, and i need to order my stall converter yet.
im going with the gm shorty's,(i have had 2 vehicles with shorty headers and single exhaust that have run in the 10's, this car will have true dual exhaust and a cat back system so flow isnt an issue)
i have heard the pcm will be the same as the 2008 LS3 vette, so i already have HPtuners ready to go
Look into LG's G6 line of cam's The G6-3 or the G6-4 would probably make a great cam for a 413/416 LS3.
Headers... might want to check and see if the Long tubes for a G8 GT will fit, since the cars are built on the same platform.
LS1Tech Sponsor
Lucky you! I have a couple of LS3 Crate engines and a Harrop Supercharger for an LS3. Since my car will be the GMPP "Bolt on" project car they won't let me come out swinging
With the Automatic and the cubes I would stay VERY mild. It will be a sleeper for sure. 212/218 will give it a bunch of torque and make decent power.
Mine is a 1SS stick car with no options. Should have it built in the first run.
Robin
Robin
