Rearmount cars chime in.
Old 10-09-2008, 08:16 PM
OUTLAWZ RACING's Avatar
Default Rearmount cars chime in.
I did some street testing my psi per gear. This is how it breaks down I have a manual boost controller also. My psi set range is 14 at least thats where Im tuned at. My car is a six speed car also. Im tryin to get a feel of what psi per gear every body else sees, From a roll or dead stop. Im gearing up for the mile oct 25 and wondering if im gettin the best out my set up.
1st. 12.5 and a lot of wheel spin. dead stop
2nd.14.5 30 mph roll and a lot of wheel spin.
3rd. 14.8 30 mph roll and a lot of wheel spin.
4th 15.5 40 mph roll and a little wheel spin.
Old 10-09-2008, 08:18 PM
Oh im not sure where boost kick in but im guessing 3,500 or 4k
Old 10-09-2008, 08:38 PM
Schantin's Avatar
You're always going to get a lower PSI in 1st and sometimes in 2nd because the engine can't produce the load needed to genreate the necessary exhaust volume to spool the turbine. Simply a matter of the efficiency from the gear ratio reducing the load on the engine by mechanical advantage. In the higher gears that advantage is less and the engine has more load, thus more exhaust gas volume to spool the compressor.
Your numbers look pretty good considering the above. Would not complain with hitting 12PSI in 1st on a 6-speed car I could only hit 3.5 on my STS in 1st gear with the wastegate set to 5PSI........
BTW, that boost lag shoud decrease with each gear. If you're seeing positive pressure at 3.5K RPM in 1st, it should drop around 3K RPM by 3rd and as low as 2.2K by 5th gear.
Old 10-09-2008, 08:42 PM
Zombie's Avatar
boost set at 16psi
1st gear, 16psi roll or dig
2nd gear 16psi roll or dig
3rd gear 16psi roll or dig
4th gear... 404 gear not found
Old 10-09-2008, 08:44 PM
hawk584's Avatar
10psi in all gears
Old 10-09-2008, 08:54 PM
Originally Posted by Zombie
boost set at 16psi
LOL!
Th400 works like a **** but I like rowing the six speed.
Old 10-09-2008, 08:57 PM
Yeah you make prefect sense. I guess im good, I do hate the 3.73 gears now but I wont be able to change befor the mile date But atleats I know my system works pretty good.
Old 10-09-2008, 09:36 PM
Schantin's Avatar
You're doing DAMN good having 3.73's. Some 3.08's will do you wonders for spool times!!!! You have the rest of the car wired tight to get the boost you're getting with those gears
Old 10-10-2008, 09:25 AM
geeteego's Avatar
boost set at 16psi
1: 8-9psi
2: 11.8
3: 11.8
4: 11.8
Old 10-10-2008, 10:33 AM
smoke20's Avatar
1ST - 8 psi
2ND - 9psi
3RD - 9psi
4TH - 10 psi
Quick Reply: Rearmount cars chime in.
