water leak?
Whoops just posted in the other thread.
The antenna is basically one solid unit, it has to be replaced. In my case I outsourced to my local mechanic cause I'm lazy. I have my old antenna. I'll take you a photo when I get home.
Yup, you'll have to drop the head liner to get it. Once you get the headliner down you'll be able to see where you can unscrew the antenna. I just ended up putting a new antenna on. You might also be able to seal it up with a caulking gun and some sealant or epoxy.
