purge
purge
Is it possible of ruuning a dynotune dry kit without a purge? My kit is on the way but if I can I want my nitrous be more of a secret. I've been sprayed by some that said they didn't have it, wasn't hooked up, or messed up and they have some *** whoopings coming! I'm trying to get my hustle on and it ain't as easy when you purging and someone know you fixing to spray! I know the purge get air out of the line but is the air in the line what causes cars on nitrous to sometime backfire or is that only on cars with wet kits? This is my first nitrous experience I figured with it being a dry kit the purge would be just to make the car run more consistant! Right or Wrong?
__________________
__________________
All the purge does is exactally what you said..it just gets rid of the excess air in the line so that when you go to spray that your getting pure nitrous. I dont think that it is a problem if you dont use a purge but i wouldnt recommend it cuz you have no way of getting the excess out of the line once your finished.
