brakemotive brakes
Old 03-17-2010, 12:05 AM
TheMonteMan's Avatar
Default brakemotive brakes
i know theres already a thread on here on them but im starting my own. just got my power stop rotors from brakemotive on ebay. they were 189. for all four rotors drilled and slotted with ceramic pads. ill be installing when i wake up. ill be sure to post before and after pics. i cant wait. my current rotors are really warped. anyways heres some teaser pics.
Old 03-17-2010, 06:53 PM
brakes are on. but, im getting a ton of noise from the rear and was having a tough time getting the rear rotors on. anybody thats done the rotors on these have a similar issue? my ebrake only locks one wheel as well.any help would be appreciated.
Old 03-17-2010, 07:15 PM
Count of Monte Carlo's Avatar
I have the same brakes on my car, put almost 40000 mles on them so far without any issues. They are naturally alittle grindy when you get on them hard. As for the parking brake, I cant imainge it being out of adjustment. On VERY IMPORTANT thing, when you put in the upper slider bolts for the rear, don't put too much grease because it will build up at the rubber end and when you tighten up the slider bolt it will actually start applying the outer pad on the last few turns.
Old 03-17-2010, 08:16 PM
Mgpeagle's Avatar
Those look sweet.
-Mike
Old 03-17-2010, 09:05 PM
LS4_SS's Avatar
yeah i have had no problems with mine at all either.
Quick Reply: brakemotive brakes
