Wheel Question
according to the guy on my other forum running the bullits anything under +30 and you start to stick out. heres the thread i think i posted this on here before half the pics arent in it anymore but he had one of his friends car and it looked bad.
http://www.montecarloforum.com/forum...ad.php?t=16922
i thought you were talkin about running +24? i think it would make a difference that from +34 with 255s. you saw the pics of his on that post. i wouldnt want to go any further out then that.
what do you mean? if your flush now and you add almost a whole inch going out it should stick out by almost a whole inch. right?
34mm minus 24mm is 10mm, which is just over 3/8". It would look fine in the rear, but 3/8" more out in the front may look funny...
34mm minus 29.5mm is 4.5mm, which is just under 3/16" - not noticeable to the average joe...
yeah, thats what i said... the OP said 29.5mm offset, plus the wheel is 9" vs my 8", so the extra 10mm offset, plus the .5" of extra width (the other .5" is sticking out the inside) is .89" total sticking out vs my wheels...
didn't the person with the 275's have a GP? maybe they have wider fenders... plus the offset is what confuses me... mine is 40 on an 8" wheel... i think if i used a 255 tire, they would stick out considering my 235's r flush... i wish i had a wheel with around a 45-48 offset... every wheel i've seen is 38-40 with an 8" width... anyway... back to the original subject...
i think on a gxp its a whole different thing. the spacing on the gxp wheel has to be different and its an 8in wheel not a nine inch plus the fender has to have more room. just speculation on my part. i really wouldnt **** with 30 or lower unless they were free, but good luck i expect pics regardless.
GXP front fenders are "wider" than non GXP Grand Prix fenders. Now whether that relates to a "wider" fender versus a Monte Carlo or not is purely speculative.
You'd either need official measurements or straight up test fitting (trial and error).
