LS1/LS2/LS6 intake swap Sticky!!!
Old 05-16-2013, 07:22 PM
  #161
Dom87SS's Avatar
Shortening it would require me basically redesigning it. It 2 faces are set at a length and you make a lofted surface between them. So to shorten it I'd have to reset the length and remake the lofted surface. Plus its just OD that got bigger, ID s5ayed the same and flanges got larger radius at mating surfaces to help with load if there is much present. I could do an FEA analysis to see where the issues are but didn't think the weight of the TB and CAI was enough to worry about.
Old 06-06-2013, 10:56 AM
  #162
Tomkat3012's Avatar
Noob question warning, I'm in the step of the swap with the drilling for the hose fillings. Could someone go more in depth with the placement of the hose couplers and if I use a ls4 throttle body do I still have to drill a hole in it or is it just for the specially designed tb adapter
Old 06-06-2013, 11:00 AM
  #163
Tomkat3012's Avatar
NM I jupmed the gun I looked through the thread and found it
Old 06-15-2013, 09:15 PM
  #164
Moderator
91parkave's Avatar
Getting ready for the ls2 swap now I bought it already port matched and tb inlet already ported. I took it further by knocking out all the posts inside. In this configuration it will be the same as or slightly better than a ls6 just with a 90mm tb.
Also for what its worth anybody whose installed these, should be aware of the 3 piece sonic welded design and vacum leaks with alot of GM intakes on gen 4 engines. i took care of the outer casing by plastic welding the whole outer case to lower case area to prevent this from happening, along with hand painting to help keep it airtight.
Old 06-16-2013, 10:35 AM
  #165
GXP25's Avatar
Are you using DoD/AFM? If so, you don't have to shave the bottom of the intake with the G8 VLOM.
I've had the LS2 intake, LS2 throttle body, G8 VLOM, and LS3 injectors sitting around for a few months now. Just need to find some time.
Old 06-16-2013, 12:37 PM
  #166
Moderator
91parkave's Avatar
Nah Im switching over to the denali 6.2 non dod valley cover. Its completely flat and seals off each oil passage. And at the price
of 43bucks, you can't beat that.
heres the pics
Old 06-16-2013, 08:23 PM
  #167
GXP25's Avatar
I got the G8 VLOM ~$30.
When you modified (welded) your stock VLOM, did you have to remove all of the rubber stuff on the underside? If so, how did you go about removing it?
Old 06-16-2013, 09:29 PM
  #168
x11 nut's Avatar
GXP 25 - Where did you get the G8 VLOM ??
If you ever head south, give me a heads up!
Cheers
Old 06-17-2013, 04:30 AM
  #169
Moderator
91parkave's Avatar
The solenoid tray has like 10 or 11 torx head bolts. Remove them and take the solenoids out then remove the solenoid retainer plate and the gasket will come off. Pay careful attention as you disassemble the tray.
Old 06-17-2013, 07:48 AM
  #170
x11 nut's Avatar
91 - pics look good, looking forward to your results.
Old 06-17-2013, 01:25 PM
  #171
Moderator
91parkave's Avatar
Thanks, it'll be hard to get some dyno time soon. Unti then its all various numbers in HP tuners to see airflow. I'll make sure I post about it though
Old 06-17-2013, 08:13 PM
  #172
Moderator
91parkave's Avatar
Good to know everything works with the ls4 fuel rail. Got the spacers in and everything fits wonderful. My only concern is the entry of the spacer, its centered and the ls4 rail comes in at a offset angle so I will drill out the inlet to mimic the factory fuel injector inlet. to make sure there will be no issues. using a step drill is ideal for this but you could always use a drill bit.
Size:  62.1 KBName:  IMG_20130617_225531_zpsb74019b7.jpg
Using a spacer for the rails isnt neccesary however if you wanted you will need a approximatley 12mm spacer.
Old 06-18-2013, 09:19 PM
  #173
x11 nut's Avatar
91 - what spacers did you use? I got some FAST adapters but they didn't fit...
Old 06-18-2013, 10:28 PM
  #174
Moderator
91parkave's Avatar
Yea I ordered the fast ones to however they fit on the bottom of the injector which is retarded. So I looked on ebay . I'll post the link when I get home.
EDTI: heres the link
http://www.ebay.com/itm/Convert-turn-your-LS3-LS7-injector-into-LS2-injector-spacer-extender-adapter-/181152371269?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2a2d85d245
Old 06-19-2013, 09:24 AM
  #175
GXP25's Avatar
fieroguru already laid out what injector spacers and fuel rail spacers are "needed."
I'd get them versus having those bolts sitting like that and having the fuel rail floating like that. They're very cheap too.
Old 06-19-2013, 09:27 AM
  #176
GXP25's Avatar
Cheers
eBay.
I barely travel lol but if I do I will.
Old 06-19-2013, 11:12 AM
  #177
Moderator
91parkave's Avatar
Theres more ways to achieve the same thing. Think about something why would my rails be floating around the bolts hold the rail down on the injector spacers and fuel injectors. There's compressed like they need to be in the intake manifold. There's nothing floating around. And if you read thoroughly through my previous post you'd see where I mention spacers and the size if you need them.I'm smart enough to know that my fuel rails shouldn't float. Try for youreself.
Old 06-19-2013, 06:23 PM
  #178
GXP25's Avatar
I'm just pointing out that fieroguru already explained what would be needed.
It also makes good practice to have spacers so as to not over torque those bolts. Without the spacers, the rail "floats" due to the tension of the rail.
Originally Posted by fieroguru
McMaster.com part # 92510A801 are aluminum spacers 5/8" in length, 3/4" OD and with a 5/16" hole. These work great to mount the LS4 fuel rail to the LS2 intake and cost $2.30 each or less than $10 + shipping. Then you can either run the LS4 injectors with the injector spacers or the longer LS2 injectors w/o spacers.
I am tuning the LS4 w/ LS2 intake/fuel rail/injector/TB/MAF in my Fiero and wanted to swap back to the the stock LS4 injectors to dial in the MAF upgrade. So with the ebay injector spacers (about $50) and some 5/8" tall spacers (or two 3/8" nuts stacked) the LS4 fuel rail and LS4 injectors bolted into place on the LS2 intake w/o issue.
Once you ditch DoD, the LS2 intake/TB/MAF swap is pretty much a bolt together upgrade. Sure the LS6 intake is better, but simple and lower cost have their merits too.
Old 06-19-2013, 10:21 PM
  #179
Moderator
91parkave's Avatar
Yea but theres a multitude of spacers to choose from on ebay, i just posted the correct ones used after making the mistake of ordering the p.o.s F.A.S.T ones. as for the spacers yea, thats why i mentioned them in my post. The FAST ones go on the bottom of the injector. Not even sure why they sell ones like that. and as for the proper ones i still think there is work to be done on those which is why i made the note to bore out the openings to match the fuel injector openings. There are also other issues i posted about in previous pages..
Old 06-20-2013, 09:11 PM
  #180
DuronClocker's Avatar
Awesome, I just bought that same valley cover the other day for my ported LS2 swap. Also paid $42-43 shipped for it. Cut off the OPSU bung, tapped the hole, and plugged it with a 3/8 NPT plug.
I'm going to be feeding my OPSU with a 4AN line from the little oil bypass cover on the oil pan by the filter. Just need to pull that and drill/tap it.
Going to use the stock LS4 fuel rails and injectors with the FAST injector spacers. They look to be exactly the right height.
I'm too cheap to pick up an LS2 TB for now though so I picked up some 5/8" aluminum to make an adapter out of.. I just need to find the time to do it and then swap everything on.
Quick Reply: LS1/LS2/LS6 intake swap Sticky!!!
