Service Brake Assist/ traction control
Old 07-08-2011, 08:53 PM
BigBlackBoxChevy's Avatar
Default Service Brake Assist/ traction control
Soo... For some reason the last week I've gotten, Service Traction Control, and Service Brake Assist to come up on the DIC. I'm also getting strange TPMS readings, 7 PSI one day, and 60PSI the next. The battery is a year old and I cleaned the terminals and cables when I started having the issue.
BCM, ECM issue?
Scheduled to take it to the dealer on Tuesday. :-(
Old 07-09-2011, 02:52 AM
Aaron_Provost's Avatar
Could be the speed sensor in the wheel hub
Old 07-09-2011, 04:14 PM
Panther427's Avatar
Well who know with our BCM maybe a wacked out TPMs will cause thouse problems too
Old 07-09-2011, 05:45 PM
DavidGXP's Avatar
i had a broken steering position wheel sensor.
same issues
Old 07-09-2011, 05:47 PM
DavidGXP's Avatar
take the car in to the dealer for a scan. thats what i had to do.
Old 07-09-2011, 08:42 PM
I figured it out! :-)
Had time to poke around today. I grabbed the R/F ABS sensor wires and moved em around. It made the ABS lights go crazy, I pulled it apart to find a broken wire where the wires make a 90 degree bend. Clipped, and spliced back together, no issue now.
It's amazing that one sensor controls the ABS, traction control and TPMS.
Thanks for the help!!
Old 07-10-2011, 02:06 AM
Panther427's Avatar
LOL you will be suprised what will cause the ABS, TC, StabiliTrac, ect go off in the cars. There are tons of sensor all connected through the BCM. Yaw, Steering, brake pedal position, ABS, ect.
Quick Reply: Service Brake Assist/ traction control
