Is a Thermostat a bad idea ?
ive been looking into them but what do our cars run normally if i do it is a 180 worth it or should i just get a 160? anyone know where i can find a 160? thanks
Not sure about these cars, but 160 is pretty low for most engines. And in some cases will set off a CEL. Most SBCs make peak power around 200 degrees F. So 180 will let the engine run in the 175-190 range which is fine for most engines. Lower temp running engines can reduce retard but ts not a guarantee that it will.
Bad idea..
Aluminum engines make peak power around 210-215*
Iron engines hold in the heat, so peak comes in around 185*-195* as posted above.
With my fans re-tuned; my water temp (Stock T stat) sets at 195* and gets no hotter the 215*
LS1Tech Sponsor
and the stock t-stat in our cars is already a 187* unit...
no need to change it... leave it as is...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
