Finally Installed my Hogan DP!!
I finally got around to installing my Hogan DP today... a lot easier than I thought it would be (the lift helped) Damn thing leaked at the rear though, so I bought a gasket and exhaust sealer and put it back togther.. Now I have to run around for a few days, retighten and send my man Lew a log, then we shall see how much this thing helps me out.. The real pisser is, I found out that the tops of the mufflers are rotted out, so there goes another $600-$700 bucks (maybe I can milk it another year or so??)
OP, the DP should give you a little more top end power once Lew re-tunes it. Definitely one of the better mods to get the most bang for your buck. Especially if you pick one up that's used. Did you go cat or catless?
