Brembo Calipers ?
Old 08-24-2014, 09:41 PM
Sint3k's Avatar
Default Brembo Calipers ?
Does anyone know of any larger Brembo calipers that will work on the 06 monte carlo SS to replace the stock ones and will work with the current rotor Looking for Front and rear replacments. ?
or
if you have another suggestion for bigger breaks front and rear
Thanks
Old 08-24-2014, 10:10 PM
08 pimpala ss's Avatar
or
Thanks
Theres a couple of different routes u can go gxp brakes and rotors all the way around or these in the front http://shop.zzperformance.com/store/...-Calipers.aspx And Gxp's in the rear
Old 08-24-2014, 10:29 PM
x11 nut's Avatar
Caddy CTS-V Brembo 4 piston calipers are the way to go if you have larger rims.
Old 08-24-2014, 11:03 PM
Moderator
91parkave's Avatar
brembos will fit on the gxp stock wheels however with monte wheels and the offset diffrence, i dont think itll work.
brembos are awesome though, i have them currently, If youre intrested in the GXP fronts we can make a deal im sure.
Quick Reply: Brembo Calipers ?
