replacing the timing chain with a c5R
hello guys/gals i was gonna be going into my engine soon to replace the timing chain was wondering whats the best way to remove/replace the timing chain since you have to remove the oil pump which that looks like it takes the oil pan to be removed the get to the oil pump pick up tube, i thought i saw someone do this job without removing the oil pan just was curious would save alot of time lol
Moderator
If you're gonna remove everything while doing the cam. Your oil pan gasket might as well get changed too. It's not really a involved extra step. But I'd rather be safe then sorry that the pickup tube gets fully seated in the pump. Also you can order the new chains Hinson motorsports that are seamless and stronger than c5r
ok cool yea that what i was kinda thinkin about as well u already there u no, i think the c5r will be ok for what i got. guess i need one of those engine support racks/bars to hold the engine in place while i drop the subframe and oil pan
I used an engine support bar from harbor freight and it worked fine and is inexpensive.
