teardown has begun!
#303
lol its doing well, tuning is going forward nicely, had to do some more startup tuning as the damn thing kept bogging and stalling when it was on a hot start. Pulled about 20% off the cranking fuel multi table, added some cranking spark and made some idle airflow minimum changes. Fuel trims are dialing in nicely, i did a run today on the highway and it shifted perfectly at 6150rpm into second, and was holding low 900's high 800's o2mv.
#307
#309
Info would be great. Part numbers you used also if available and if you noticed a difference. I have used Earl's line before on my previous Camaro's and noticed a much harder pedal feel after installing which I liked a lot. Thanks
Edit: I see after reviewing some old posts they were ZZP extended lines. Any other options for our cars available? Still interested in how the pedal feels but you don't have a stock set up anymore so that could be different from what I would see as for gains.
#310
