View Poll Results: Would you buy a set of poly motor mounts?
Yes - power to the ground is awesome !!
16
84.21%
No, I need the money for my spaceship.
1
5.26%
Maybe, if I get permission.
2
10.53%
What!?!? There's nothing better than squishy mounts !!
0
0%
Multiple Choice Poll. Voters: 19. You may not vote on this poll
Full Poly motor mount set... Prototype
Old 05-09-2015, 04:11 PM
Moderator
91parkave's Avatar
Jesus auto correct on the phone murdered that one. Trans mount I'm referring to the driver side mount. Are you using solid poly like I am or using a molded piece
Old 05-09-2015, 06:38 PM
x11 nut's Avatar
Figured as much, no worries. Yes, both the mounts are molded.
Old 05-11-2015, 06:54 PM
saltybreadstick's Avatar
i know i had been emailing with you about getting one of your front mounts...but i'd totally buy a set of these. minus the drivers side trans mount as i already have a super nice poly trans mount
Old 05-12-2015, 11:11 AM
Mels SS's Avatar
I want a set
Old 05-24-2015, 11:36 AM
Sint3k's Avatar
Can we order these now or wha
Old 05-24-2015, 09:51 PM
08 pimpala ss's Avatar
They are not available yet its in the works be patient. But let me tell you they are awesome it will be worth the wait. Do you have x11's front mount?
Old 05-25-2015, 01:41 AM
Sint3k's Avatar
No, where did that aluminum dog bone mount come from, im kinda waiting to do them all at once. I dont drive the MC but once a month or so. My front one is broke again , 2nd time now.
Old 05-26-2015, 10:28 PM
dog bone is from zzp for intense racing
Old 06-06-2015, 03:20 PM
GXP25's Avatar
Any update on this?
Transaxle has to come out for the rebuild, so while I'm at it, I want to change all of the mounts.
Also, is it worth changing the subframe bushings as well?
Old 06-10-2015, 03:51 PM
GXP25's Avatar
*bump*
Old 06-10-2015, 07:16 PM
x11 nut's Avatar
Still waiting for a quote on a production run. That and it will be good to see how they handle Pimpala's over boosted LS9 Cam combo...
Old 06-11-2015, 07:23 AM
  #32
GXP25's Avatar
Care to expedite this?
My transaxle should be coming out next week or so.
Old 06-11-2015, 05:31 PM
  #33
x11 nut's Avatar
So looks like I'll be able to get the two cast mounts (rear & side) in @ 3 weeks. I'm in the middle of moving so I'm not sure when I'll be able to make a front mount next. That said, the front is easy to change if you have to do it later.
I should have pricing tomorrow.
Old 06-13-2015, 01:30 PM
  #34
GXP25's Avatar
Any update on the price?
Also, would the 1" shorter dog bone have any effect on these mounts since they're pretty much solid?
Old 06-13-2015, 04:29 PM
  #35
superglide9375's Avatar
hey x11 what is the other one that i don't have i got one from u,now u made another one for the same mount or other mount?i like your work so would like to see which one I'm missing ,thanks
Old 06-13-2015, 09:03 PM
  #36
x11 nut's Avatar
So it looks like the mounts will run about $150 plus shipping... Not too bad considering they are small volume cast poly with stainless steel - should be the last mounts you ever buy for an LS4! I'm using my last fabricated front mount to get a molded front mount prototype done so we can get all 3 lower mounts in cast poly.
No, the shorter dog bone will not work - with how stiff the poly mounts are it won't line up. The mounts have been fab'd up & test fit with the ZZP polished dog bone, so I'm going to see about doing a bulk order with them so every mount needed will be in one box...
Old 06-13-2015, 09:24 PM
  #37
GXP25's Avatar
Thanks!
That's not bad considering the low volume.
How much do you think adding in the front lower mount would add to this cost?
And to clarify, the ZZP polished dog bone is only a cosmetic change, correct?
Old 06-13-2015, 10:07 PM
  #38
x11 nut's Avatar
Hey man,
I've got prototypes for the other 2 lower motor mounts - they are pictured in the beginning of this thread. This way we will be able to have a full set of poly motor mounts.
They should be available in a few weeks.
Old 06-13-2015, 10:12 PM
  #39
x11 nut's Avatar
Thanks!
Just so we're clear that's $150 per mount.. Trying to get the set of 3 for $400.
The polished dog bone is more rigid as well as cosmetic, but shouldn't be necessary with 3 lower poly mounts - stock dog bone will be fine unless the cosmetic is the important part.
You want to be first in line ??
Cheers
Old 06-13-2015, 10:24 PM
  #40
thanks for info x11 will be in touch
Quick Reply: Full Poly motor mount set... Prototype
