anyone boosted with ls9 cam
looking for someone on boost that has done what im about to do i know its been done just would love to hear how it is. Kevin said a few of his customers have done it.
Just wanna know if there is any additional parts i might need or if someone could just make me a list please
after a ton of searching i think i finally found some light at the end of the tunnel thanks
http://www.grandprixforums.net/threa...ssible-sticky*
you can use any LS cam in the ls4, just have to make sure you use the right gear, other then that everything is pretty much as plug and play as every other LS engine. I have that 3 bolt gear with the 4x pickup and the matching GMPP heavy duty chain. My car came with the single bolt gear. As long as your doing the DoD delete you dont have to worry about exceeding the maximum lift specs of the DoD lifters. Just make sure you have enough valve spring to match whatever cam you choose.
