Misfire on Cylinder 4
im getting a leak down test done. the mechanic trying to charge 2k says he did one and everything was fine. the mechanic helping me today highly doubted that was done. spawne32 do you suggest running the injector cleaner through the rail? also do these come with a connector to hook up with the rail since the connector any suggestions thoughts anything i will be hitting a auto shop tommorow to test theories and everything to try to eliminate as much as possible.
The stuff you dump in the tank isnt going to cut it, they do sell injector cleaning kits but they are expensive, you can do a makeshift one with homedepot parts.
DIY Fuel Injector Cleaning & Repair - YouTube
Edit: I never pulled the injectors to do it. Pulled the fuse for the fuel pump and the car ran right off the injector cleaner. It was along time ago, I dont remember the brand of cleaner but it was commercial stuff for sure. The line I used I believe was from a fuel pressure gauge, cant be sure now.
Yeh i have heard of some kits that hook up right to the fuel rail, i just gotta locate one, my buddy has a couple cans of the 3m stuff that does that but you need an adapter.
spawn a adapter or wtv i need to fix my ride and not break me nor my car would be great if you can lead me in the right direction. to many guesses and hundreds spent as mechanics to charge me for what they think. Does anyone think that it could be a lifter? its just idling really rough but i get good throttle response which really confusing me. i figured a collapsed lifter would cause alot of other codes as well as the misfire.
also i read and heard from a buddy that if i run the seafoam through my oil gas and vacuum from booster, as well as seeing videos this could unstick a lifter has nayone every done or seen this actually work
dont be sorry rottenj any help is help anyone with a suggestion trick something to try is better than were i stand right now with my baby running like crap and hating every minuete of it
#33
Why not just swap the injector and see if the misfire follows it... if the misfire does follow it then take that injector out and rig up something to blow injector cleaner thru it and energizing the injectror off and on
#34
#36
update
leak down test fine on all injectors except one swapped the injector and still same code on cylinder 4.
ran the seafoam as instructed and no change.
read somewhere on threads to try to pull o2 sensor and see if the cat was clogged or bad so i did and got a p0030 HO2's heater control circuit bank 1 sensor 1 which i figured i would get and a random misfire code again.
any other ideas?
talked to GM and they say this isn't a known issue.....always not the manufacturer issue. Probably going to be the last gm I purchase even though I loved GM before this car. Love the ride hate fixing it every payment being the same as fixing the car. At this point replaced everything but the lifters, and the manifold gasket for exhaust.
anyone think this could be caused by exhaust leak? or any other ideas tired of running around trying to figure this one out.
oh and i also checked harness for wear on the wires or chewing or anything nothing is exposed nor cracked cut anything. cant seem to pinpoint this at this point and time.
any other ideas?
#38
#40
