Who makes the 3 in exhaust system
We don't have a single exhaust system, we have a partial dual system. Which means you have to do your calculations by 1.5. 2.2CFM per horsepower x 350hp = 770cfm, Dual 2 1/4 inche pipes at the smallest section of the tail pipe, 408cfm x 1.5= 612cfm total possible flow through the tail section. The mufflers are only capable of flowing UP TOO 700cfm each. Not to mention it even says in the article "The table above is probably over-estimating pipe size, but you can see that a 400 hp vehicle with a dual exhaust system only needs 2 1/4 – 2 1/2 inch pipes. Anything larger is overkill."
I am already running 3" for a large section of the single pipe that runs to the dual section, then it briefly reduces to 2.5" before the split. Your getting into a whole different realm of possible theories there, we could talk about exhaust velocity and scavenging at the point. I am not saying that a 3" probably wouldnt net a little more power, it probably would, but not enough to warrant the extra noise, weight, and cost for me. Very confident that without the cat in place, this system flow just plenty for the volume the engine produces.
if you already have 3 inch back why not just replace the y-pipe with a 3 inch in and dual 3 inch out muffler? then just have a shop make the rest.
i did that with my factory exhaust but with 2.5 in and dual 2.5 out. sounded pretty good and got rid of that tiny y-pipe.
Spock quotes aside, i understand the suggestions, you just have to have faith that I know what I am doing because I have experience with this. I have had too many cars, from wbody cars to honda's that have lost low end torque by double digits from oversizing the exhaust. I always default to the minimum required size based on my calculations now and it usually nets me good results. Common logic is to always go to something really big because the thought behind it is that a big engine requires a big exhaust, so everyone always defaults to 3" without actually knowing why. And sure you can make big power on a dyno running a 3" exhaust, I am sure, but there are other factors to consider like i said. Regardless of the size of my intake or the mods I have done, this car probably puts down somewhere between 300-315hp to the wheels, modestly. There is no reason at all for a 3" exhaust on this car, and barely enough justification for a 2.5".
http://www.gomog.com/allmorgan/exhaustbackpressure.html
Moderator
So if you understand the principle behind the engine being a air pump why do you not understand more air needs to be pushed out? You keep going to these sites saying airflow for a dual system or airflow per pipe. But that does not out line efficiency. Not to mention your websites get the majority of my information from eras where tbi was still the new thing. Your never gonna lose tourqe on a 3inch system either it's simply a shift in the power band
Hell gm decided to use 2.5 inch piping already on 4.8 trucks and such. I don't see how you come to this conclusion that a cammed 5.3 do sent need more.
Any chance of you getting to the dyno before install? I'm not saying this to be a dick or try to prove you wrong somehow, you should know me better than that by now. Just would be good to actual have some before and after type results. These manufactures all claim nice results, but those are never the real story. I know when the K+N system first came out for these I believe it said like 28hp, now I think it says 13.48 lol. Those mufflers will sound good for sure, and are not overly loud as I have used them on a few cars in the past.
If i can find someone who has decent prices for 2-3 runs then yeh ill do a dyno before and after. I still have quite a bit to do before this exhaust is completed, i have the procomp wideband gauge I have to setup and get this zzp trans mount installed. Also gotta figure out why my steering still feels funny. It feels like im running something over in turns, but the suspension is all tight and everything seems to be fine. Tires are also screeching at low speed in some turns.
#33
Moderator
#35
#37
i like the trubendz, trust me, like i said i considered alot of factors, cost being one of them. I got these pieces at a fraction of the cost, plus they are slip fit which makes it easy as pie for me to do in the driveway. Pictures dont do it justice its quite a bit larger, the smallest section on that pipe is 2 1/4, the ends are 2 1/2 or just under on the ID. The mufflers are huge compared to the stock ones. There is a couple hundred CFM bump here regardless of how it looks.
#38
Looks like that 3" inch exhaust would drag under a lowered car...that's massive...however I've been following your guys exhaust thread and I'm still not sure what set up I wanna do. If I'm following correctly, a 3 inch set up is good no matter what, with or without mods, or if I'm mistaken that's a 2.5 set up cause stock is like 2.25? and also spawn I wanted to ask do you use your gxp as a DD?
#39
Moderator
#40
Edit; I just noticed you said even as a DD, I'm assuming that also is even with your cam and intake etc...
