Couple ?s for you guys
What are possible symptoms of a fuel pump bitting the dust?
What are possible symptoms of a fuel pressure regulator going out?
Just trying to narrow down a problem i am having with my car.
Here is a link that will take you to the symptoms i have described:
https://ls1tech.com/forums/lt1-lt4-modifications/1005500-fuel-pressure-problem-maybe-help.html
Thanks guys
Devin
Thanks guys
Devin
You can check the FPR by pulling the vacume line off of it and looking for wetness or if it smells like gas.
Hook up a fuel pressure gauge to the check valve on the fuel rail.
Depending how many miles you have on the pump Most all I have replaced in gm's have been around 130k and up on the mileage Do you have a Fuel pressure gauge? If you pinch your return line your pressure should double if it does then the pump is ok
when my fuel pump was goin out i could only tell when i tried to accelerate past like 65 mph cause the car would choke and stutter so i had it checked out and sure enough the fuel pump and filter was goin out. I think i was only pushing out 35% instead of 100% man that was an expensive repair.
