New write up, crank hub removal and installation
I keep seeing that alot of people are having trouble with this on the forums so I decided to do a write-up today explaining things step by step. Hope I didn't leave anything out. The methods used here were by me and if you use a different method that is fine, this is just what has worked well with me.
http://www.lt1engine.com/tech/remove...lt1-crank-hub/
Village Troll
Couple things, if I may...
The chain/hub thing looks like it'll work fine for an auto. For a manual the only thing required to do is put the car in 5th gear and pull the e-brake.
The other thing is it really isn't a good idea to tap on the crank hub when installing it. It can damage your thrust bearing. Here's a very easy, cheap install tool to make:
http://members.***.net/gmarengo/Misc/Misc.htm
That is the same as asking why didn't I just use a vice grip or why didn't I chain the flywheel or why didn't just use an impact gun or why i didn't just losen the bolt with the belt still on. I used a chain because it was the first thing that came to mind and if I tried to use a crescent wrench I can already imagine the headaces of it slipping off and dropping tools. I might snap a picture with that method and add it to the page.
