few stroker ?s
few stroker ?s
i hav two questions wat is the length pushrod i need to use? and also my dad has a set of harland sharp aluminum roller rockers 1.6 ratio will these fit with stock valve covers?
stock length should be 7.20, i believe. lt1's use self aligning rocker arms. make sure those are, or you'll need to run guide plates. which inturn will require hardened pushrods. BTW, i dont think the valve covers will clear those rockers.
