eliminating accessories
Old 11-29-2008, 05:43 PM
fast414's Avatar
Default eliminating accessories
hi there i was thinking about getting rid of everything and only running the water pump, alternator, and crank pulleys. if im correct i would be getting rid of the power steering and a/c right. and is there a kit you can buy to help you do this ... thanks
95 z28
Old 11-29-2008, 06:18 PM
Formula350's Avatar
You'll most likely have to get an alternator relocation bracket to keep the alternator spinning the correct way (older Delco's don't matter which way, not sure if newer do). Might as well just run an electric water pump while you're at it, since I assume you're wanting to do this to free up parasitic loss. If you were just doing the AC compressor, there's a delete pulley for that (1LE performance package).
Old 11-29-2008, 10:20 PM
LS1 SPEED's Avatar
The alternator will need to be relocated with a kit if you want to ditch the A/C & PS. We offer 2 kits : 1 which is alternator only and 1 if you did want to keep the PS, but ditch the A/C and clean up the look of the engine bay.
if you ditch the PS I strongly suggest a manual rack and not looping the stock rack
MadMan Racing makes a great rack we can get you into as well for $640 shipped
see link for alternator kits we offer
https://ls1tech.com/forums/sponsor-s...only-kits.html
Old 11-29-2008, 11:00 PM
Black94Z28's Avatar
I plan on getting the manual rack this spring. I just deleted my PS, but for now, looping the lines will have to do. I hate being broke!
Old 11-30-2008, 06:17 AM
fast414's Avatar
what do you mean about looping the old stirring and how long will it last... i have 3.5" weld on the front
Old 11-30-2008, 07:31 AM
the_merv's Avatar
Taking the two Fluid Lines from the PS Pump and looping them, bypassing the Rack.
Old 11-30-2008, 11:18 AM
SoxXpupPeT's Avatar
LS1 Speed's brackets are beautiful! if i was getting rid of my AC id definitely be getting one of there set ups.
Quick Reply: eliminating accessories
