How to clear codes on OBDII TA?
Old 12-01-2008, 05:26 PM
highwayman's Avatar
Default How to clear codes on OBDII TA?
I've tried to clear the code on my '96 TA with no luck. Before, I could just pull the PCM IGN and PCM BATT fuses and leave them out for about 15 minutes and it would clear. Now, I can remove every fuse, disconnect the negative battery cable, turn on the light switch and the code still remains. Is there any way to clear the code I don't know about? My scan tool does not have a function to clear trouble codes. Thanks. MJD
Old 12-01-2008, 05:42 PM
Badazz 97 TA's Avatar
well if it keeps coming back then there is a problem that needs to be addressed. clearing it wont get rid of it permantaly. if the system see's a problem it will keep popping on the SES light. what codes is it?
Old 12-01-2008, 07:06 PM
impaled's Avatar
if you cant read the code. check the CIG/ACCY fuse (on the driver side of the dash on the interior), if that fuse blows your OBD2 port doesnt get power.
