Nitrous Question
Old 12-08-2008, 05:23 PM
BlackTA96's Avatar
Default Nitrous Question
What the max you guys would run on a stock bottom end? I want to run a 200 shot. is that too much?
Old 12-08-2008, 05:25 PM
Elliott's94Z's Avatar
Me personally I wouldn't. It will only last so long. I would stick with a 100-125 shot to be safe. 150 at the most.
Old 12-08-2008, 05:31 PM
Schweet97Z's Avatar
Im with Elliot
Old 12-08-2008, 05:40 PM
bombebomb's Avatar
100 shot, 75 to be completely safe.
Old 12-08-2008, 05:52 PM
Jditlfm's Avatar
My last engine was a stock engine with bolt ons. I Started using nitrous at 130,000 miles pretty heavily. I started with a 75 shot moved up to a 100 for a while. 15-20 bottles later I moved up to a 150 fwhp shot I did that for about 4 bottles then i moved up to a 175fwhp for 3-4 bottles and it spun rod bearings 5-6 one day when i was off spray. I had all the safety equipment, upgraded fuel pump pulled about 8 degrees of timing for the 175 shot window switch all that. Times in sig were on the 150fwhp shot. It lived but eventually it took its toll on it. You can run that much spray just be prepared for it to let go when using that much 100-125 is the most i would go on a stock bottom end if i wanted it to last.
Old 12-08-2008, 08:04 PM
camar0corey's Avatar
Yes. Just a bit much.
Old 12-08-2008, 08:16 PM
LS1 SPEED's Avatar
150 should be issue free with proper fueling and tune
200 will take the life out of the motor quickly if not suddenly
Old 12-09-2008, 07:18 AM
BlackTA96's Avatar
ALright. I'll stick with the 150
Old 12-09-2008, 09:11 AM
Just be sure you get all the safety features and the correct the timing with a 150 shot.
Old 12-09-2008, 09:54 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
So true....Back when I still had a stock short block...I was running a 150 shot, and was going through 2-3 bottles a week...did this for almost 2 years. When I pulled it apart to build the stroker...the pistons, bearings, etc, all looked fine.
Old 12-09-2008, 12:22 PM
94FBIRD's Avatar
150 here for a few years now. Countless bottles. No problems.
Old 12-09-2008, 01:01 PM
robsquikz28's Avatar
150 for years no problem but i know people with 150 or even less on there cars and guess what kaaabbboooommm i think its just like or when its ur time its ur time...that it but have fun and on the safe side and always know it can kkaaabbooommm at anytime it may want too
Old 12-09-2008, 01:09 PM
texas94z's Avatar
150 shot max as said, however 200 shot for the ls7s or 03/04 'bras .
Old 12-09-2008, 02:36 PM
Armyman2445's Avatar
IMO that is up to you. If you want to spray a 200 then do it. If you want to spray a 75 then do it. Just know for every action there are concisquinces (I know i cant spell). I sprayed a 175 on a 121,xxx bolt-on motor for about a year. The motor was still running strong when I tore it down for a head cam swap. I always so if the tune is fine tuned enough it will be fine. But thats my opionion.
Old 12-09-2008, 07:46 PM
transamws6_97's Avatar
i know a guy that was running a 300 shot on a stock lt1. not the i recommend it i'm just saying it can be done. He did it plenty
Old 12-10-2008, 03:49 PM
JOSH13's Avatar
I'm not trying to hijack or anything but I'm considering a wet kit for mine would that have any effect on how big I could go ? Also what would need to be tuned to run a 150 on a bolt on car ? I do have tuner CATS by the way ....
Old 12-10-2008, 04:17 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
PM Sent
Quick Reply: Nitrous Question
