Valvetrain set up
Valvetrain set up
Im doing LE2 heads, with LE3 or LE 3.5 cam on a stock cube LT1, I have talked to Lloyd, and everything is a go.
The only thing i was wondering is valvetrain set up.
I want it to last, i hate redoing valvetrain.
I was thinking of doing a Jesel set up. Who else is running shaft mount rockers? What brand you running?
Thanks
Thanks
Thanks
Thanks
IMO, Jesel shaft mount for your application is severe overkill. Pick up a set of Comp Camps Pro Magnum non self-aligning rockers, ARP 7/16" rocker studs, a good set of hardened (or chromemoly, if you have the dough) pushrods, and GM guideplates. That's plenty reliable.
