Fidanza and Spec Flywheels
Old 12-29-2008, 06:35 PM
transamws6_97's Avatar
Default Fidanza and Spec Flywheels
Does anyone know the weight for the spec aluminum and billet steel flywheels? I was looking at fidanza and theirs is 12.5 lbs but what just curious as to the weight of specs but if the aluminum is that much heavier than fidanza ill just go w/ fidanza
Old 12-29-2008, 09:57 PM
crookedbowtie's Avatar
I believe Fidanza is the lightest available. I think all others are around 15lbs and the steel isn't even close if you are worried about a few pounds.
Old 12-29-2008, 11:36 PM
well looks like im going w/ fidanza since i was looking at getting a spec clutch and that was the only reason i was considering spec but i happened to fall into a deal where basically i get almost 2 mcleod twin disk setups for pretty cheap so ill be going w/ that and selling the steel flywheels for an aluminum
Old 12-30-2008, 07:29 AM
blackz6sp's Avatar
Yeah I can't remember exact weights, but when I was researchin fidanza was the lightest.
