inner door water deflector
Old 01-02-2009, 07:41 PM
rspears9's Avatar
Default inner door water deflector
im trying to get the plastic cover that goes inside the door to keep water leaking inside car,but dealership said it has been dicontinued,does any one now were i can get one,i need it real bad.you see it when you take the door panel off.
Old 01-02-2009, 08:15 PM
k0261886's Avatar
junkyard is your best bet
porksoda's Avatar
Just go to a furniture store and get a huge piece of plastic from them and cut to shape for your door and tape it up. I work at Sears and almost all our fridges come wrapped in that thick plastic and some washers and dryers do too.
Old 01-02-2009, 08:21 PM
Elliott's94Z's Avatar
Yup..I would check out a local wrecking yard if you got one close by. Seen them there at my local yard
Old 01-02-2009, 11:50 PM
shbox's Avatar
It's just a piece of plastic that is held on with some rope-type mastic. When the body shop reskinned my driver's door, they never put it back on. It hasn't cause me any trouble in the past 8 years.
Old 01-03-2009, 12:55 AM
sweet-94z28's Avatar
I have one if you need one.
Old 01-03-2009, 09:34 AM
rspears9's Avatar
Default water deflector
how much.i live in kimper ky.i need it for the driver side
Quick Reply: inner door water deflector
