help with pistons rings
hello guys ..someone please help me out...i bought this forged pistons
with one guy ..they cam in 0.30" but i donīt has the pistons ring
anyone knows where i can get it??
and in the other side of the coins...may i used an original pistong rings and make the gap?? how knows the part number for those pistons rings???
i am stall only for this ..so please help me guys
thanks in advance
regards
paco
pd. my car is a trans am 94 350lt1 evrethingīs stock i only change the psitons and the internal metals.
thanks in advance
regards
paco
You need to find out what size rings they need. Some newer LT1 pistons come with metric rings. Most likely you will need a 1/16", 1/16", 3/16" 4.030" ring set but it is possible you need a 1.5mm 1.5mm 3.0mm 4.030" set.
Thanks,
Shane
Thanks,
Shane
thanks to all of you guys....
today ..we allready change the pistons rings i get these for a mexican company called
carpro..they soldme in 0.30...and we put it 0.20" extra because i am thinking in use a nitrox later
regards
regards
