94 supercharged camaro problem skipping !!!!!!! help
94 z28 vortec charger 6 psi ,at idol cant really tell it unless you listen very carefuly under load it is kind of like a loss of power after a few sec's it comes aound then at high rpm range it get's a lot less noticeable! what's the problem???? i am supposed to buy this car tomorrow , is it the opti or something else ??? whit kind of power does it probaly make was told over 400rwhp ? i dont know alot about lt1's but is that realistic( ls1 guy ) .
Sounds like it needs a tune/running really rich. My h/c lt1 had same problem...it would load up and make little power then break free a bit as rpm's raised, I put a new coolant temp sensor in the water pump and it runs great now. The car was running extremely rich, getting super shitty gas mileage with no power.. Could be something as simple as a $15 fix like a sensor...
A s/c lt1 can make over 400rwhp. But the bottom ends do not like boost...at all.
