Transmission Yoke O-ring
I bought an aluminum driveshaft off someone on here to swap out my stock one. I am rebuilding the aluminum shaft with new u-joints so I know they are good. There is a black o-ring on the inside of the yoke (transmission side) that is cracking. Should I replace this o-ring, if so does anyone know its name or part #?
Thanks
Thanks
Yeah, it isn't leaking because it is part of the driveshaft. It is pressed into the steel yoke on the driveshaft. I am thinking they might have put it there so the yoke doesn't bump into the tailshaft housing.
